#14527 09/08/05 06:18 PM
What type lubricant is recomended for the inside of the vacuum motor? I have read about graphite mixed with alcohol but is this ok for the long haul? Seems to me some sort of grease would be better
#14528 09/08/05 09:34 PM
I give mine a shot of MMO ever now and then. I just pull the hose off the manifold, stick it in a small capful of MMO and work the wiper arm back and forth by hand, it don't hurt the engine either!
#14529 09/08/05 09:53 PM
Thanks Mack, but how does that get the MMO up into the wiper motor?
#14530 09/08/05 11:00 PM
It gets sucked in by the action of the wiper motor....I prefer to use ATF as its kinder to the rubber wiper hose.
When the motor was new grease was used arond the paddle in the motor.This grease gets hard after 50+ years and the ATF can soften it up a little.The same for new motors that have been sitting around for long periods of time.If the " treatment" dosen't work they can be taken apart.cleaned and regreased.
#14531 09/08/05 11:24 PM
What i did with my wiper motor in my 31 was, take it apart and clean all old grease out and smear vasoline inside of it. It works great. I have heard of others doing the same thing.
These ain't for old guys any more.
#14532 09/08/05 11:45 PM
HMMMM!!! Gene, maybe that is why I have to replace the wiper hose every 20 years give or take a couple of years! Maybe I should switchn to ATF...Nahhh, I like the smell of MMO burning early in the morning...... devil bigl bigl
Vasoline is the lube that I use when tearing a wiper motor down...Man, don't those things have a pascel of itsy bitsy tenny parts under that little tin hump!
#14533 09/09/05 12:39 PM
Does this process sometimes get oil into the cabin area?
Chevy lover
#14534 09/09/05 12:46 PM
No, because my wiper motor is under the hood or on the outside of the windshield, also on cars with under the dash wiper motors, I haven't noticed any oil spots, after you suck a few drops of oil into the wiper motor, once the engine is started any oil excess oil will be sucked into the intake.
#14535 09/22/05 05:04 PM
Mr Mack, you mentioned replacing the hose.--what did you use?
paul orednick
305 canal st
lemont Il
60439
