Posts: 298 |
Could someone please verify that this is the correct VIN for a 1930 roadster. 21AD 48522. Thanks, Andy.
Posts: 298 |
Thank you. This is for DOT identification purposes.
Posts: 6 |
Is this number on a body tag or frame no. or engine no?
Posts: 3,163 |
The number they are refering to is a car serial number on a small metal tag nailed to the floor of the early cars. There are no numbers on the frame as F**D used. Some states will use either the car serial number for title purpose & some states use the engine number. I had a vehicle with a Washington state title that used the engine number. When I brought it to Arizona MVD choose to title it from the car serial number ....Joe
