Both door checks on my 52 sedan front doors are broken. The new check links came in today but I havent a clue how to replace them. They came with 2 rivets. Any help would be greatly appreciated!
The replacements I got for the 52 had no rivets, to install you need to remove the kick panel and look slightly up the check link on my 52 bolts to the body at the A pillar. Very simple install. talk
thanks for the help, they went in easily!
