#144626 05/31/09 12:52 PM
shawng Offline OP
Is there supposed to be a light spring that goes from the tiny eye at the end of the clutch pedal to the crossmember? The crossmember has a hole in the right place with a cotter pin in it to make a hoop and what looks like the remnants of a spring.
If this is so, it would hold the pedal from rattling around and keep the throughout bearing from slapping against the pressure plate.
It's not how fast you can go, but how good you look at 20 MPH.
Sounds like you answered your own question.
David Baldwin
shawng Offline OP
any ideas on dimensions?
Shawng
will measure my 27 for you today and respond. I cannot remember if mine has one, only replaced clutch last year. comes with age I guess.
Ken
I have a 1927 Chevy Capital AA 4 Door also a 1927 Chevy Touring car, a 1936 Chevy 1/2 ton and a 2010 Corvette LT3 Convertible and a 1953 Packard Caribbean. My tow car is a 2011 Suburban.
