Posts: 156 |
I was out testing My 31 when I noticed I was going to turn over from 77999 to 78000 miles on the trip. A bit later I first noticed my speed indicator swinging more than normal? Later I looked down and "NO SPEED" My first thought is my cable or a end fitting broke. But after a while I questioned if the turning over jamed the unit maybe due to age? I would expect this is wishful thinking but I thought I would confirm. My final question is ...does anyone know where I can purchase a new cable if needed.
Shocks
Posts: 3,578 |
Is there a specific lube to use on the speedo cables?chef-
Chevrolet recommend motor oil or a light grease.If grease is used apply only a light coating on the lower 2/3's of the cable,This is to prevent the grease from working its way up into the speedometer head.
Posts: 326 |
The Chevrolet garage that I worked at in the mid to late fifties dipped the cables in 90 weight gear oil let it drain a bit and put it back in,this was done almost daily on some kind of vehicle and with our cold winters there was no problems.I did a few as my part time job of turning back odometers the rest of the time I was the painter.
woody
Turning back odometers? :eek: :eek: :eek:
Posts: 156 |
FIXED..!!! I took it apart and found the break just about five inches from the transmission connection. What had happen over time is that it rubbed againist the break linkage arm. It finally worn throu the outerjackey.
To fix I cut the cable shield back and also installed the transmission gear fitting on the new cable. Re-installed and it appears to be working fine.. Thanks Guys.
Shocks
Posts: 326 |
JYD We had a 53 Bel Air that didn't show its age [it was well cared for] that was traded in two times and had about 100,000 miles total but sold fast as a40000 mile car.A friend who worked with me at the time remarked just the other day about that car and how quick it sold,if they had only known what they bought.Could be why we have laws about odometer changes.
woody
Posts: 4,951 |
Good to hear you got the cable situation fixed, Shocks.
"Rolling back" speedo's (actually odometers) is an interesting situation. Lots of folks, myself included, don't think much about some of the silly "consumer protection" laws.
However, most think the one about not tampering with speedometers is pretty good.
Bill.
Posts: 326 |
I agree that it a dishonest practice but this was on the order of the owner who claimed to be an honest new car dealer,at least that is what the general public thought of him.A few of us knew better,I moved on to a better place to work shortly after that.
woody
Yep, and I'll bet that a lot of dealers that were considered honest had the odometers rolled back as well. I can remember when, as you indicated, rolling back odometers was a common practice. :( :( :(
In the 1940's and 1950's it was legal for a dealer to zero a speedometer on a used car....in Wisconsin...an most higher milage cars were.Many dealers and private people also cheated on the milage.
Thats why I laugh when some one says their 1947 Chevrolet has 30,000 actual miles...if they only knew its history.
Posts: 11,162 |
Yeah, There was even 16 year old kids working at service stations and salvage yards that learned how to "roll'em back" guess how I know? Kinda like Rice Krispies, Snap! Crackle! and Pop! Snap it open, crack it apart, roll it back, and pop it back in. It would kinda be hard to make anyone believe it now days. five slick offbrand tires and only 9000 miles on the odometer? Ha!
