#14402 08/29/05 08:58 PM
I am attaching the drive shaft to the transmission on a 1932 Coach. The trunnion bearing collar is on, but there is slop from side to side. I can't see how this can work, unless the torque tube serves to stabilize the drive shaft. Is the joint sloppy? Is the collar directional? Thank you.
#14403 08/29/05 09:42 PM
The torque tube "aligns" it wink
#14404 08/29/05 10:06 PM
Also......there is a right way and a wrong way to install the trunnion bearings. The ID hole with the radius goes against the "U" joint yoke.
wink laugh laugh laugh
