#143990 05/23/09 09:58 AM
trooper Offline OP
What is the 171 4cyl compression supposed to be? I recently pulled a compression test and got a 70psi on all 4 cyl.Am I in good range? trooper
You are in a good range. The compression ratio is ~5:1 Calculating 5 x 14.7 lbs atm. pressure givens 73.5 lbs as the calculated pressure.
