#14390 08/28/05 02:25 PM
I have the larger axle in my 1932 Coach. Could someone please help me by furnishing a modern double sealed bearing number? The Fafner 307pp is for the smaller axle.
#14391 08/28/05 02:59 PM
I'd suggest you call George at Olcar Bearing Co. in NC, he provided my double sealed bearings for my 31 and has all that info, fair prices too. phone 910 693-3324.
Dick
#14392 08/28/05 03:40 PM
You should be able to take your old bearing to any bearing supply house and they can convert the numbers to a double sealed bearing. The same size bearing will have several different numbers depending on seal or no seal, single seal, or double seal.
See you down the Back Roads.
Joined VCCA June 1, 1961
