I assume I'll be starting a debate, but I want to get as much information as I can to make a good decision. I'm restoring a 1941 Chevy Special Deluxe coupe. I have stainless steel brake lines, which I cleaned and flushed with alcohol and blew out with my air compressor. I cleaned all the junctions. I also installed a new master cylinder and all new wheel cylinders. I'm not sure what type of brake fluid to use. My car will be driven probably weekly during the spring and summer, occasionally during the fall, and not at all during the winter (it will be stored in my unheated garage). What brake fluid should I use? I hear that dot 3 is corrosive to paint, which I've spent (and will spend) lots on new paint and powdercoating. I hear that if your car sits a lot, the wheel cylinders can leak with dot 3. (If I used dot 3 and pumped the brakes weekly over the winter, would that keep them from leaking?) But, I hear that dot 5 can lead to spungy brakes and sometimes water accumulating in the system. As you can see, it's like I'm starting with a new system, so I'd like to do the best thing all around to have good brakes, but protect my paint, etc. What are your recommendations/experiences.
Thanks in advance to all who may respond.
Charlie
