Posts: 112 |
What could I expect to pay for a 31 air cleaner for my car and how hard is it to find one. Thanks
Posts: 3,163 |
And...if you're lucky enough to find one with the decal still on it.....let us know....Joe
Posts: 558 |
Or a 32!!!! I need a picture to reproduce the 32 decal...Hopefully.
Posts: 523 |
last year i saw an air cleaner at a swap meet that the guy wanted 150$. the thing was a rusted out dented piece of junk that wasn`t worth 10$
Posts: 112 |
Thank you guys for the information. Appreciate it.
Posts: 168 |
I have one for a 31, that I would swap for one from a 30, similar condition. 31 has the rounded end correct?
Ron
Rounded end??? All of the 1929-31 air cleaners have a round nipple where they slip into the air horn of the carburetor. Are you talking about the top of the air cleaner? If so, the top of the 1931 air cleaner is flat and it is rounded on the edge.
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
Yes the main body of the 1931 air cleaner/silencer has a one piece pressed body which has rounded corners (Rear.firewall side,not carburetor side), the 29-30 are made of muliple pieces with a sheetmetal folded seam joint on both ends of the body similar to a food can.
JACK
Posts: 168 |
I can send a picture if you like. The 30 air cleaner is somewhat "flat" on the end pointing towards the firewall. Air is sucked in on the carb side of the unit. The 31 air cleaner is somewhat "rounded" on the side pointing towards the firewall.
I was just at a swap meet and picked up an air cleaner for for the RJH-08 carb. However, on this one the air sucked in on the firewall side of the cleaner. I think it is off a chrysler. I may use it because it has the hole for the tube that goes to the crankcase. The 31 aircleaner I have does not.
Do they make a reproduction tube that attaches the crankcase vent to the air cleaner?
The air cleaner that you purchased at the swap meet is probably an early or late '29 Chevy. They are different as the crankcase tube is at the back (firewall) of the block on the early one and ~ 1/3 of the way back from the front on the late one.
The 1930 air cleaner is not flat! It looks like a round tuna can with a big dome on top. There are fins on the back of the air cleaner (carburetor side). The air cleaner with the fins on the firewall side sounds like a 1929 Chevrolet air cleaner.
