Posts: 51 |
On the bottom of the shifter shaft bracket which is mounted on the steering column, what goes in there; a bushing or a bearing to keep the shaft in alignment?
There is a bushing in the stamped support that is attached to the column. Its part # 3693802, fits 1950-1954. is 1" o.d. 19/32" long.
Posts: 51 |
Hi Chevy Nut, Thanks for the info on the bushing . I now have to find a place that has it. Thanks again Blu j 123
Posts: 3,801 Likes: 1
Posts: 3,801 Likes: 1 |
Some NOS and repro stores allow you to "search" by using the GM part #. Thanks to Gene, that part has been solved, allowing you to search with confidence.
Good luck !
