#141463 04/20/09 03:59 PM
jwp Offline OP
Can any one provide the dimensions, material and material condition of the rivits use on the 1928 ring gear? I am thinking of purchasing a ring and pinion set that is short several rivits and I would like to know that the correct rivits are available prior purchase. McMaster Carr does lists several different rivits in its catalog and I hope that one of them will work.
jwp
jwp #141468 04/20/09 04:32 PM
After you purchase the unit, you can take a sample around and you will find something.
devil Agrin
dont wory about rivits just bolt it in . i think this has been discusses before . hope this helps
