#141031 04/14/09 10:05 AM
j1932 Offline OP
I have a 1934 GM truck engine that I am rebuilding my question is next to the oil pump about midline on the block there is a 3/8 threaded hole. If I blow compressed air into the hole I feel air in the cooling system. What is this hole for, can it just be plugged?
Jay
j1932 #141032 04/14/09 10:10 AM
I believe it is for a coolant drain cock.
1936 Low Cab Pickup
j1932 #141033 04/14/09 10:11 AM
j1932 Offline OP
That makes sense.
Thank you
Jay
j1932 #141047 04/14/09 04:26 PM
When you say it is 3/8 are you sure it is not 1/8 NPT? Don't mess up the threads.
Joined VCCA June 1, 1961
j1932 #141050 04/14/09 05:27 PM
j1932 Offline OP
Yes, it is an npt thread. Thanks for the warning.
Jay
