i just puchased a 57 chevy pick up from california, I know this is a little out of the usual, being this club is geared to original cars. good running truck , not the original engine or rear end, possibly the original tranny First off i have a problem with the drive shaft rubbing against the crossmember of the frame, Ive been told the pinion angle could be off. Ive been also told i should set it to the angle for the rear end, not a 57 chevy truck. So first question ,The rear end is a 10 bolt,with a stamped groove in the pumpkin. numbers are 3894859NF, anybody know what that is off of and or the pinion angle for it? Next question, It is a v-8, thinking a mid 70s-early 80s, Got some numbers off the block, by the firewall, Passenger side, GM3970010, Anybody able to tell me what it is.Also, any help on how to set the pinion angle would be appreciated. Im also guessing that a easy fix would be to add a leaf to each of the rear springs, But id hate to make it ride rougher,not a cushy ride now. thanks guys, Bill Pearson
