Posts: 188 |
A friend has a 69 SS Chevelle with power disc brakes. It has the baseline 396 so vacumn should not be a problem. At times the brakes work fine/normal-power brake feel and stopping. Other times, a lot more foot pressure is needed-almost like brakes are fading. Original booster replaced twice, both times with rebuilt booster. The problem is still not fixed. Any suggestions Thanks, Lou 44888
The next stop should be the master cylinder............
Posts: 188 |
The master cylinder was replaced when the first booster was replaced. Car has new lines and rubber hoses
I believe that those did not have a vac. reserve tank, the reserve was held in the booster. There should be a check valve plugged into the booster. If this was not holding vacuum there may be a loss of vacuum in the booster.
