Was there a gasket or foam insulater between the heater and the fire wall to stop air flow through the fire wall. I looked through several catalogs but did not see any heater insulators Thanks, Harold Pickett
There is nothing shown or mentioned in the instructions. The heater hose holes them selves are to be 3/4" , this would prettywell fill the opening. The only other two holes would be the ones for the heater mounting studs. The cars all had the holes pre-drilled, for trucks it was necessary to drill the holes.
