#13670 07/29/05 04:38 AM
zodiac Offline OP
CAN ANYONE HELP WITH THE MODERN EQUIVELENT GEAR OIL FOR THE GEARBOX AND REAR AXLE ON MY 31 PHAETON,HAVE FILLED WITH EP140 BUT IT FEELS TO THIN AND NOISY ALSO LEAKS OUT OF ALL THE BOLT HOLES,CAR IS A SOUTH AFRICAN KD,R/H/D,SO REALY NEED THE OIL TO SAVE ANY PROBS WITH STEERING BOX
#13671 07/29/05 09:00 AM
I know exactly what you mean. I had the same problem when I first used modern gear oil in my '32. The Filling Station (www.fillingstation.com) sells a heavy duty 600W gear oil that matches what originally used to go into these old cars. If I recall correctly, this gear oil has microfibers that help prevent drips.
#13672 07/29/05 10:13 AM
I got mine from Little Dearborn in St Paul Mn. They are all F..d guys but if you have a place like that around you they can set you up with the 600w
These ain't for old guys any more.
#13673 07/29/05 10:29 AM
All of the Model A F*#d vendors sell 600W.
#13674 07/29/05 10:39 AM
I thought that discussions here a couple years back were in favor of modern, multi-viscosity gear oils...
ok epi
#13675 07/29/05 01:47 PM
The modern oils are fine for the 1932 and up but some of the worn out older ones do better with a heavier oil.
#13676 07/29/05 06:42 PM
zodiac Offline OP
DONT FORGET IM IN UK SO CANNOT GET MY LOCAL VINTAGE **** MAN TO MAIL ME SOME 600W,ALSO POST MAN WILL NOT SEND OIL OVERSEAS EXCEPT IN TANKERS,HAVE EP150 STILL SEEMS THIN
#13677 07/29/05 07:18 PM
Being as I reside in an agricultural region, read the sticks, I can get 600w gear oil off the shelf. They still stock it for combines, etc. They have farms in England?
Regards, Gary
#13678 07/29/05 09:32 PM
SAE 160 is the modern number for 600W oil. It is also sold as "steam oil". Don't know the equivalent in Europe but should not be too tough to find.
#13679 07/30/05 03:29 PM
I don't know anything about these gear oils. Mobil still makes 600w which is a steam cylinder oil. This has a similar consistency as 140W. The tech rep from Mobil said that this was fine for our tranmission/rearend applications. He stated that some of the new gear EP oils use sulphur base additives which can react with brass and bronze bushings.
I called Lubriplate some time ago and talked with their tech rep and they said that they have a gear oil SPO-277 which is comparable to today's 140w or Mobil 600w. It is a modern oil that doesn't contain the animal fats of the 600w. He and Their website literature says it is safe for bronze, brass and silver alloy. He also mentioned the SPO-299 but said the literature didn't mention about other metals. www.lubriplate.com or Technical Service Center:800-347-5343
Doug
#13680 07/31/05 12:04 PM
zodiac Offline OP
HAD A WORD WITH MILLERS TECHNICAL SERVICE,IT SEEMS THAT 600W ALTHOUGH HAVING THE SAME VISCOSITY OF EP140 DID HAVE SOME ADDITIVES TO PREVENT SEEPAGE FROM FELT SEALS AND THREADS ALSO TO STOP THE OIL SHEARING ON GEARS,THERE WAS NO SOAPS OR SULPHOR ADDED SO THE YELLOW METAL WAS NOT AFFECTED,I HAVE CHECKED OUT COMBINE HARVESTER AND MACHINERY OILS THESE HAVE ADDITIVES IN THEM TO COMBAT ROUGH USAGE AND DIRT MOST SEEM TO HAVE SULPHOR IN THEM TO KEEP THEM STABLE IF WATER OR CONDENSATION GETS IN,I WILL FIND OUT SOMEHOW,WE DO HAVE OLD **** PEOPLE OVER HERE WILL SEE WHAT THEY COME UP WITH
#13681 08/01/05 09:46 AM
zodiac Offline OP
WELL GUYS FOUND THE LAST 20LITRE DRUM OF 600W IN THE UK,IT SEEMS MOBIL WERE THE LAST TO MAKE IT,THEY HAVE A 206LITRE BARREL OF IT AS WELL SO ANY UK BASED SPECIALIST READING THIS CAN GET IN TOUCH-------SORTED AS WE SAY OVER HERE THANKS
#13682 08/01/05 03:15 PM
zodiac Offline OP
oops seems like writing mail in capitals is not done!!!!!!!!!!so appologies to all hope you understand as old guys like me have only just got used to this electricity thing,paul boothby
