Today my starter decided not to work. I'm willing to bet it has oil on the commutator but that's not the topic I want to talk about. The car had started right up as usual when I realized I'd forgotton my wallet. So I shut the car off and ran inside to retieve it. When I got back in the car nothing happened. Everything else worked except the starter and the owner.
Back when I was a kid we had a tractor that could only be started with a hand crank. I have fond memories of that tractor. I also remember it kicking back one time.
That was about 45 years ago and I haven't used a hand crank since. At this point in my life I have a bad back and the thought of a kick back scares me to death. But I was he77 bent and determined to take that car for a ride. Out came the crank. Set the spark, turned the key on, and one pull of the crank and the engine was running.
I made several stops in town and the starter worked each time but one. One pull of the crank and it would fire right up. After I got home I let the engine sit several hrs and tried it again. It started on the first pull but stalled before I got to the spark. Had I set the throttle a little no doubt it would have kept running. After that it took about 10 pulls but it fired up.
It's a good feeling to know I can use the hand crank if need be. I have no desire to make a habit of it but it was fun.
Something tells me I don't want to start it with a hand crank on a cold winter day after the car has sat for several weeks. In a case like that it might be better to hitch a horse to it and pull start it. :vcca:
That or just ride the horse.
