#135719 01/28/09 02:14 PM
jolo Offline OP
Does anyone have a recommendation for the torque specs for the cylinder head on the 1933 Master 206 engine? The 1933 Chev Repair Manual gives the bolt tightening sequence but not the torque specs.
Jolo
If you are using old bolts I would stop at about 50 or when you feel the bolt stretching.
Agrin devil
How about new bolts?
1936 Low Cab Pickup
I would not exceed 65-70 lbs with new bolts. There is no need to go even that high to get a good headgasket seal. 55- 60 lbs is plenty.
