Posts: 22 |
Greetings All ! I am preparing to replace the head on my ’32 chevy. It has been running on 5 cylinders for quit a while now and as a tribute to the stove bolt six, it has performed pretty well. Now I’d like to see what 6 cylinders feels like. Some years ago I was told that the head on my ’32 was actually a ’31. I decided to look for the correct head, have it reconditioned and put it on the car. I now have the reconditioned head and as I do the planning for the job some questions have come up. I made an identification of the new head which may not be accurate. The numbers on my new head are 836718 CONV 12 and D 14 2. Can anyone out there id this head for me? Also, since the head currently on the engine is a ’31, are the rocker assembly and push rods going to be an issue or could I assume that if they work with the ’31 they will also work with the new head (a ”˜32 I hope). Finally, I would appreciate your views and guidance on having the rocker assembly reconditioned (recondition the shaft, grind the rocker arm and install new bushings). I see that the Filling Station offers this service. I have not taken the valve cover off yet but I am not sure how to evaluate the need for replacing the bushings when I get there. Any advice and or information is welcomed. P.S. I have been reading the posts on this forum (I finished about 65 of the 171) and I wish to thank you all for the education and information I have received. ……..Greg
Yes, according to the cylinder head casting number and the casting date, you definitely have a 1932 cylinder head. I would stay with the 1932 rocker arms and shaft. Also, going with reconditioned rocker arms, shaft and bushings is highly recommended.
Posts: 22 |
Junkyard Dog, thanks for the confirmation and advise. I'll be starting this week.
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
There was a change in the ratio of valve rockers in 1932 .
The 1932 rockers increased the Valve lift from .277" in 1931 to .309" in 1932. this was to compensate for an advance of 8 degrees in valve timing.
You may have to measure valve lift with a dial indicator to check and see if you have 1931 rockers or 1932 rockers.
1932 valves were also a one year only valve.
JACK
The '32 rocker bushings and shafts are also larger diameter than '29-'31. If the push rods center in the holes in the head then you should have the right rocker arms for the head. If to one side then they are not. The part numbers are on the rockers, shaft supports so you can tell that way also.
Posts: 22 |
Jack and Chipper thanks for your help from ”˜Down Under’ and ”˜Deep in the Heart of’…… it will take me a few days to get to a dial indicator and I am sure the valves are ’32. I did pull the valve cover and found the number on the shaft support matched my 29-32 Parts Price List (836813) the rocker arm was another story. The number in the Parts book was 836765 the rocker arm I removed is 836873. It can’t be 29-31 since there is no ”˜wick’ hole and the shaft diameter obviously matches the shaft support. My parts book seems to have some flaws or it is incomplete……..Any thoughts???......Thanks….Greg
The parts book number does not match the number on the part. In the parts book you find the part number. Perhaps the number on the part is a casting number. Life is NOT simple.
The 1931 rockers i have has a forging number on the valve end which is 335549.
The shaft diameter measures approx .725"
I don't have any 1932 rockers or shafts to compare numbers.
JACK
In your case you are seeing the casting number.
