Looking for an answer to this one also and am assuming someone has it.....I may have alreay been given a response to this but for whatever reason I need to ask it again and maybe am looking far a little more info so that I can put this to rest. I will aks here again anyway and I will ask each question in an individual line so there is less confusion, thanks for any help on this
1st I have a casting date of E-17-29 I get that E must refer to the month of May and have looked thru the casting # info given here but I must just be missing it there myself, is it possible for someone to copy and paste that info here from the appropriate casting info, it may seem obvious to alot of you guys that know that info front and back and it may be there in black and white but I simply do not see it.
2nd... given a # by chip of 27763...squesntial number for coaches built in Flint plant...help me to understand what that means exactely where did he get that #.........this was already partially answered but I am still confused as to the # 27763, was this the # of coaches buil in a particular plant for that years?
3rd and last, since I do not have the serial # for my car as it has been removed at one point I am trying to figure out how the motor # might give me some details on when my car may have been manufactured so that I can more accurately pinpoint paint options ect that would have been avail during that time frame unfortunately I cannot copy and paste in the correct format what I assume I should be looking at here but it is labeled
1929 U.S. CHEVROLET MOTOR SERIAL NUMBERS BY MONTHS
1929 INTERNATIONAL SERIES AC
NUMBER OF FIRST MOTOR USED EACH MONTH
is this the correct area and can someone help me to better understand this graph, I see alot of blank spaces in many months until I get to bottom but cannot see why
