#13505 07/17/05 11:08 AM
I have been troubleshooting an overheat problem on my 32 coupe for a few years now. Here is the problem car will run fine around town for quite some time and remain cool but a few miles on the highway creates overheating. Eventually around town driving will also cause same problem. Here is what I have had done: Engine has been rebuilt (this was when problem seemed to become worse), replaced water pump, reverse flushed engine and radiator, removed head and pressure checked and magnafluxed, retorqued head, put in new radiator core from Filling Station, tried pure water instead of anti-freeze, changed timing, run with side vents open and closed and probably a few more things I can't remember now. NOTHING HAS HELPED!!
Radiator man said that the rings may be set with too little end gap, engine has about 200 miles since rebuild and runs fine other than the heating
ANY SUGGESTIONS??? Thanks
Chris Geiger #35228
#13506 07/17/05 11:14 AM
You didn't mention the water pump baffle plate. Is it installed in the block behind the water pump or is it missing? :confused: :confused: :confused:
#13507 07/17/05 11:15 AM
had a 67 vette, 427 400 hp that i rebuilt(bored 030) tried everything i could think of to keep it under 235 degrees. nothing worked till the wife and i got in it and drove from maryland to cyprus gardens fla. in january. 2000 mile round trip. never went over 200 degrees after the "breakin". 200 miles not enough to loosend things up internally. good luck. mike
#13508 07/17/05 11:28 AM
The baffle plate is in and located correctly. I had hoped that by putting some miles on the car, the engine might "loosen up" and run cooler but I can't run it long enough before it heats. I seem to be able to go a little longer with the new core but not much.
Chris Geiger #35228
#13509 07/17/05 08:54 PM
Leo Offline
Did you check for Hydrocarbons in the Radiator. :confused: :confused:
#13510 07/17/05 09:50 PM
Are you using a thermostat and if so is it the correct temperature? Also did you check the temp in the radiator with a thermometer or are you using the dash gauge??
#13511 07/18/05 07:05 AM
Leo Offline
Chris, Go to "Engine Bottom Noise" Aug,27 2002 and check that thread. I made two post's on my Overheating problems. laugh laugh
Leo
#13512 07/18/05 09:14 AM
Steve, this car never had a themostat in it and it ran fine for many years. When overheating occurs, the temp gauge pins itself and water boils out of radiator cap and overflow so I assume gauge is indicating a true problem.
Leo, Where do you take radiator fluid to check for HC? Looked on "Engine Bottom Noise" but could not find your posts.
Thanks for all your ideas.
Chris Geiger #35228
#13513 07/18/05 10:08 AM
Leo Offline
Chris, Find a smog shop, someone that does emission checks. All they have to do is sniff the neck,it only takes a few minutes. If there is any reading it indicates that you have exhaust in the cooling system. If you have exhaust getting in the cooling system it will never run cool.
Go to search, type in "Bottom Engine Noise" and the thread should come up. laugh laugh
#13514 07/18/05 10:14 AM
Leo Offline
https://vccachat.org/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=1;t=000295;p=1#000007
Chris, Try the above
#13515 07/19/05 01:48 PM
I had a similar problem with my 31. I had the radiator boiled out. I flushed out the block several times. Checked the water pump and cleaned the inside of pump(parts that are inside motor once back in) And then i put a 4 blade fan on it insead of 2 blade fan.It really helped out a lot. Oh and i put a plastic coke bottle on the end of the radiator over flow hose, mainly so i dont get antifreeze on the ground. Once it fills up i just pour it back into radiator.
These ain't for old guys any more.
#13516 07/19/05 05:52 PM
hrndog19688, Thanks for the input. Unfortunately The 32 already has a 4 blade fan and I also put a 1 gallon can on my right side splash pan to collect fluid that comes out overflow. Chris
Chris Geiger #35228
#13517 07/20/05 02:11 PM
Just a thought all the problems started after a rebuild
Did you check cam timing and are you sure your exhaust is not half pluged up?
I am going to grow up someday!
#13518 07/22/05 11:40 PM
Tom32,
I had the exhaust manifold off and checked heat door wich was wide open, rest of exhaust is flowing free. Have not had engine apart enough to check cam timing, that will come as a final staage if I have to pull engine again. Thanks for input.
Chris
Chris Geiger #35228
#13519 07/22/05 11:41 PM
Tom32,
I had the exhaust manifold off and checked heat door wich was wide open, rest of exhaust is flowing free. Have not had engine apart enough to check cam timing, that will come as a final staage if I have to pull engine again. Thanks for your thoughts.
Chris
Chris Geiger #35228
#13520 07/23/05 12:19 PM
check the water pump packing it may be sucking air at high speed . i have hade this happen several times . even if there is no leakage around the shaft it can still suck air at high speed pushrod
