Posts: 210 |
How do you remove the backlash on this unit. :( :(
Are there parts available for this unit. :confused: Nothing listed in The Filling Station Catalog.
You don't! There is no adjustment for backlash on the 1929-30 Chevy steering box. About the only thing you can do to decrease the backlash is to either take apart the box and turn the gear 180 degrees or replace both the worm and gear with new old stock units...if you can find them! Even at that, there will still be some noticable backlash. :( :( :(
Posts: 210 |
This Car just started to shimmy after hitting a bump, and the only loose thing I could find was the play in the steering box. Can I put a 32 Box in it? :eek: :eek:
Who makes a rebuild kit for the '30-31 tie rod ends? They have the spiral springs and not like the later ones.
Posts: 210 |
JYD, After reading your 1st post I went to bed thinking about finding an area on the box that may take some play out of the box. When I put the mask bearing in I went to center the steering wheel and found that there was no centering the wheel,you can turn it forever,the stops are on the front wheels.I will remove the pitman arm and see if I can find an area with less play.
I do have a spare 32 front end with the drag link and tie rod ends. I'll check to see if I can find the Moog EV-1 kit and do that first like you said.
Just checked the Parts store, they do not have a listing on the kit. Is the FS-148 on page 227 of the Filling Station the Moog EV-1? Looks like you need two kits to do the job.
Posts: 210 |
Well, as usual I ran into a snag. The Tie Rod ends off the 32 are servicable, but the Drag ling end at the Pitman Arm has the first two threads juiced up. It was a Bear to remove the screw out.I think I can save it if I had a tap large enough for the job.Will head to the Machine Shop and see if they have anything. :eek: :eek:
