Hello all!
Looking for advise on how to attach the mohair-faced beltline weatherstrip to the openings on my 39. It is the fuzzy strip where you lay your arm. I didn't take this car apart- got it as a basket case...I can see 2 small screw holes on the door portion, and can see that the strip was 'stapled' on the garnish moulding. Are there any good ways to attach it? Also, I can use screws on the outer ends of the strip that attaches to the door, but how was it fixed to the door in the middle of the opening?
Thanks for your time-
OC
