#134250 01/09/09 09:46 PM
I'd like to install an HEI dist. in a 1967 Camaro stock point ignition. How do I convert the resister wire and hook up the dual distributor wire? Pat
Jim Lewis
Become a Member!
Pat you can run a new wire from the fuse panel that is hot only with ing. on. There should be a spade terminal marked ing. Then tape the resistor wire back in the harness in case you or someone wants to go back to points. Not sure what you mean by dual distributor wire, the HEI only needs a 12 volt wire to work, the other would be for a tach.
dens41 #134343 01/10/09 09:40 PM
Dens Chevys, Thanks for your help. Pat
Jim Lewis
