rck46 Offline OP
I came across a new or rebuilt W-1 carb with a brass tag with the number 839987 on it. Does anyone know the application for this and will it work on my '37?
That is a 1941-48 carb. It will "work" on your 1937 but is calibrated much leaner than the 1937-40 carb. Due to engine changes/improvements the 1941-48 could use a leaner mixture.
I did experiment with that carb. on my 1939. The most noticable problem was a slight lean surge at mid road speeds (40 to 60 MPH). Fuel milage was about the same.
Due to the engine changes (and carb) the 1941-48 cars gave better milage.
rck46 Offline OP
Thanks for the info.
Gene,
Is there a way to identify the 41-48 carburetors vs. the 37-40 if the brass tag is missing?
Mark Yeamans
VCCA #35724
The answer is a qualified yes. The 1937 and '38 are easy because they have a unique throttle arm. It has an additional horizontal tab for the throttle cable. '37 has the two piece choke plate '38 and later a single plate. After that it can get a bit more difficult. If it has 421 cast into the float bowl it will be a '41 or later (except for those that are a replacement for earlier models). Internal part differences will identify other years/models.
Also the 1940 and older have a 1 7/16" throttle bore and the 1941 and up 1 1/2".
Don't recall if I have a 1937 but do have some 1938 rebuildable "cores".
Also, per some Carter info I have, there could be a stamped number or letter on the base of the carb where it mounts to the manifold. If you find one let me know and I will dig into my literature.
The "flange number" wasn't always stamped onto the base of the carburetor and if the carburetor did have the flange number it would usually only be on the carbs. built by Carter, not by Chevrolet.
