Posts: 118 |
I have a string going in the electrical area but need all the exposure I can get.
Had the wrong bulbs in the stop and tail lamps sockets. Was moving things around and then the passengers side stop and tail lamps BOTH came on when I put the lights on.
Now I have nothing. No lights, no horn, and of course no ignition.
Can somebody help by giving me some thoughts On where to start and what to look for.
I disconencted the 2 wires from the passenger side tail lamp assembly thinking I might have a short in that assembly but that didn't help.
John, Do you have power to the ammeter? Headlight switch? Ignition switch?
I would suspect a bad ground between the body and frame/engine/battery.
Posts: 118 |
Guys,
I stand corrected. I do have igntnion. Just started the car. Pulled the fuse from the light switch and it is blown. What amp fuse should I be using in the light switch?
Once I get the fuse replaced will still have to address the tail light/stop light issue
Thanks John
Posts: 1 |
hi i am new at this so bare with me i am in qld australia and am chassing imfo on 1929 chev trucks as i am doing one up thanks
paulallwood
Posts: 118 |
skip thanks
figures it would be a size do not have
That's the way it works!  :p
