Posts: 37 |
Hello, I have a 1932 grille shell thats all apart and polished. Its in 3 pieces. what is the best way of reassembling it. Does it need welting between any of the pieces. whats the best way to rivet it back together without wrecking anything. does anyone sell all the rivets for this. Any help would be great.
Thank You, Luke
Posts: 1,290 |
Also the Filling Station sells bolts that have a rivet looking head on them. I used these on my 31 coupe for the radiator shell and also for my hood handles. They look just like a rivet on the outside and a very easy to work with.
If you google rivet several rivet suppliers can be found, Hansen Rivet, McMaster-Carr are among them. I have purchased rivets from both of them in the past the stainless radiator shell rivets are among them. Don't remember which supplier supplied them. If rivets were originally used I use them in the restorations. Occasionally you will have clearance problems with the nuts on the the back of the bolts or screws but not the rivets.
Posts: 377 |
JYD, Where do you get the blind rivets?
Doug
