#13295 07/03/05 12:02 AM
DRHOOK Offline OP
HELLO;
I HAVE A 1929 4 DR. SEDAN,BODY#(IN FLOOR)IS 3AC32434.ENGINE# IS 334243.NOTICE LEAVE THE AC OUT AND REVERSE THE 24 & 34.IS THIS CORRECT?
wazzup :confused:
DHOOK
#13296 07/03/05 12:09 AM
Yes, both your car serial number and your engine serial number that you posted are correct for 1929. yipp laugh laugh laugh
#13297 07/03/05 12:46 AM
DRHOOK Offline OP
THANKS;
IS THIS THE ORIGNAL ENGINE OR A REPLACEMENT
DHOOK
#13298 07/03/05 02:53 PM
DRHOOK Offline OP
sorry;I SHOULD HAVE THOUGHT ABOUT YOUR ANSWER BEFORE MY REPLY.
THANKS idea
DHOOK
#13299 07/03/05 05:31 PM
Yep! ha ha! wink laugh laugh laugh
#13300 07/03/05 06:42 PM
The engine number and serial numbers were not the same.From my info the engine was probably made in March....that would indiacte that the car was probably assembeled in April...but there is no sure way of telling if its the original engine.
#13301 07/03/05 08:17 PM
Let me add to Gene's comments. Your serial number 3AC32434 breaks down as follows:
3 = St.Louis Assembly Plant
AC = 1929 Passenger car
32434 = 31434th passemger unit assembled at St.Louis for the 1929 model year. All serial numbers started at 1001.
For the St.Louis assembly plant the last Passenger vehicle assembled in February, 1929 carried Serial number 14908. The last Passenger vehicle assembled in March, of 1929 carried serial number 32758. Your vehicle was assembled 324 units prior to the 32757 number unit making my guess that your vehicle was assembled at the St.Louis assembly plant during the last working day of March, 1929.
My engine data is a little sketchy at best. It starts with the first serial number for March which was number 349222. Your number 334243 was prior to the March number, so I can only guess that your engine was assembled at Flint sometime in February, 1929.
#13302 07/03/05 10:11 PM
Sounds as if its the original engine :)
