Posts: 36 |
how do the rocker arms get oil on a AB engine ?
Posts: 11,162 |
Oh! that is an easy one. You can pull the valve cover off, and there should be a thick felt pad on top of the rockers, pour a goodly amount of motor oil and soak up the felt with oil. if you don't have a thick felt pad, get one. Then after you drive a couple of hundred miles you can use a squirt can full of motor oil and squirt it into the holes drilled in the top of the valve cover, that is what they are for! I reckon that you find it strange that there isn't an oil line coming up from the oil pump to the rockers? strange but true.
Don't forget the end of the rocker arm that mates with the pushrods. That end should have a felt ring around each rocker arm where it operates the pushrods. Those rings should be oiled each time you oil the felt pad.
Posts: 36 |
thank you very much the car i have did not have the felt so do you know where i can get it
Gary Wallace (314) 293-1991
Posts: 845 |
The felt pad and the felt rings are purchased separately and you will need to tell Gary that you want both if that is your choice.
Posts: 2,418 |
Those items/sets are also sold on eBay quite frequently.
:vcca:
Solan G, # 32797
