Posts: 87 |
I believe I have the correct speedometer cable for my '25 Touring, but not the connectors to the back of the speedometer or where it connects to the transmission. Does anyone know where i might get the connectors?
Hi There and welcome to Chevy Chatter II! On the speedometer connectors, check with your local speedometer shop. They have lots of different connectors and also custom make speedometer cables on order. They can probably help you.
Posts: 87 |
Thanks for the tip. I'll try them.
When you get the new cable, be sure to check the speedometer and insure the shaft will turn. Most 25 speedos are unoperable and the case and tower (made of potmetal)have cracked and swollen. If you don't check before total assembly you may ruin your new cable.
Posts: 87 |
Thanks Ray. That is good advice (as usual).
