Posts: 82 |
Can anyone site sources for manufacturers of the wood parts needed for restoring a vehicle. I have talked with the two advertisers in "Generator & Distributor". There must be other sources. Help?
Try Autowood Restoration in Hanana, Indiana. Go here: http://www.autowood.net/  :) :grin:
Posts: 3,163 |
For 33 to 36 wood call David Entler 717-235-2112. What body style are you working with?.....Joe
There are four professional wood kit suppliers that I know of. With the G&D ads and the postings above you have been given all of them. You also have the option of using a local cabinetmaker or other accomplished woodworker. Or you can do the job yourself. Skill level and expertise are critical to doing a first class job. Having good enough patterns or original wood is also necessary.
Posts: 82 |
Working with a "36 low cab 1/2 ton pick up. Thanks to all for the resources. Happy Holidays!
Posts: 80 |
I had good luck with Entler. Everything fit.
Posts: 205 |
I am familiar with David Entler and Jim Rodman. Who are the other two and contact info? Thanks! Johnny
