Posts: 188 |
What are the identifying features of the correct oil pan for a 67 corvette 327/350HP? sump size? where drain plug is located? and is there a difference between power steering oil pan and steering damper oil pan?
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
all 67 sbc oil pans drained from the rear of the pan. the drain plug is 3/4" across the flats. the sbc pan has a lower sump measuring 10 1/2" long.three vertical ribs stamped into the left side of the pan, two on the right. the ribs are about 1 1/2" in length. mike
Posts: 188 |
Mike, is this a five quart pan with trap door or a four quart pan?
Posts: 63 |
Link to 63-74 4QT 100% REPRO OIL PAN This links to a picture of 100% correct reproduction oil pan for 63-74 corvettes, or so they claim. Maybe this will help.
