Casper Offline OP
Hello,
Does anyone have a photo of a 1928 AB National water pump baffle in place?
Adam
Casper
hi
if u are a member you can e mail Robert Spallone at
chevy2899@msn.com
he is the club member that provides technical advice on 1928 Chevy
u should add your member number to your post you will get more response
Ken 45145
I have a 1927 Chevy Capital AA 4 Door also a 1927 Chevy Touring car, a 1936 Chevy 1/2 ton and a 2010 Corvette LT3 Convertible and a 1953 Packard Caribbean. My tow car is a 2011 Suburban.
Unlike later models, the 1928 baffle is mounted in the water pump. There is a recessed area in the water pump housing where the baffle is located. There is a hole that receives the tang on the baffle to keep it from rotating. In rebuilding the 28 pump the baffle is installed after the two bushings and is placed before the impeller and shaft are installed.
Agrin devil
Casper Offline OP
Thank you sincerely. Problem solved!
Casper
