Posts: 1,049 |
hi
I have owned this 1927 capital aa now for a week or so and have another question regarding starting and ignition
I purchased a set of points condenser cap and rotor and replaced what came with car. But, when it came to condenser I did not find one on car. I looked in repair manual and no pics on location.
Does this car 1927 4cyl have or need a condenser? If so where to put?
Also It has autolite 3076 plugs and a friend advised try hotter plug so I will look for 3077. comments please.
Is anyone aware of a repair manual better than the one that you get from e bay?
Comments on choice of oil please.
thank you for your consideration
ken
I have a 1927 Chevy Capital AA 4 Door also a 1927 Chevy Touring car, a 1936 Chevy 1/2 ton and a 2010 Corvette LT3 Convertible and a 1953 Packard Caribbean. My tow car is a 2011 Suburban.
Posts: 11,162 |
YES your car needs a condenser, if the coil is an original configuration it has the condenser built in the coil. I have replaced the original coil on my 28 with a more modern coil (off a 51 Chevrolet) and attached the condenser body terminal to the coil mounting bracket for a ground and the terminal on the condenser to the lead going to the points. You need to be sure that the sparkplugs have the correct reach.
Posts: 1,049 |
Mack got the other questions but only partially on the plugs. There are a bunch of us 4-banger gang that run Autolite 3077 plugs. Should see a little difference from the 3076s.
Posts: 11,162 |
I didn't infer that the 3077 plugs were not correct because of reach, and that reach may be a more important factor than running a sparkplug just one heat range higher factor in the old four-bangers. Using an "off brand"  sparkplug can be like rolling the dice, or opening a box of chock-o-lates......... :vcca:
