#12731 05/14/05 08:16 AM
rs50 Offline OP
I have looked all over for the running board mounting brackets with none to be found. I have decided to attempt to streighten them. What I would like to know is are they 90 degrees front to back or slightly bent because of the angle of the frame front to back? And are they 90 degrees from the frame mounting or do they have a slight rise to the end of the bracket?
I`M NOT AN EXPERT BUT THE FRONT BRACKETS SEEM TO BE BENT BACK A BIT,REAR BRACKETS LOOK 90 DEGS.ALSO SEEM TO BE 90 DEGREES DROP FROM FRAME.THATS LOOKING AT MINE.KEEP WATCH ON EBAY.WISH I COULD BE MORE HELP.
DHOOK
