#127137 09/14/08 03:32 PM
jon-l Offline OP
My 48 is leaking out the rear main seal[I think]. Can a new seal be installed while the engine is in the car? If so, what is best seal to use, rope type or newer rubber? Thanks in advance for MORE GOOD INFO.
The "rubber" type seal is for the 1955-62 only. The seal grove is too wide and deep for it to work in the older engines.
The graphite seal (rope type) sold by either Chevs of the 40's or the Filling Station is what I would use. There are several tricks to installing the upper half, the main thing is to remember it but be packed very tight to not leak. Just pulling it through is not enough.
If you change it while the motor is in the car, carefull not to drop the little shims that were between the main cap and the line bore. Now would be an excellent time to clean the screen on your oil pickup in the pan, and scrape that clean also...
I had the same problem with my 1947 sedan. I changed the seal twice and it still leaked. I don`t remember what the gentelmans name was from the VCCA but he said to find an NOS rope seal.I found one and no leaks . The NOS seal is bigger than the ones they sell today. I think sometimes older is better. I also had one of those old time rope seal pullers.I think someone still seal them. good luck.
mark47
I tried aftermarket rope seals, and they didn't hold. I bought an nos rope seal and it worked!
47 Aerosedan
41 Cabriolet
The modern replacement seals are junk. They seem to tear at the surface. I have found some GM NOS on Ebay. Saving them for future use. I believe that I posted the warning a while back. Have heard the same from some engine rebuilders also.
