Posts: 52 |
Thanks Gene. My cables are the correct thick ones with the braided earth cable. All the other wires from the regulator to the generator are tight and don't appear damaged or anything. The fan belt is also tight as it should be. My headlights are the standard T3 6 volt sealed beams, and all the bulbs are standard. The car is idling quite slowly so I can up it up slightly perhaps. When you say the battery should be load tested, do you mean turning on the lights, radio etc then testing the voltage between the positive and negative terminals when the engine is not running ? Also do you know what the voltage should read approximately ? I was thinking of replacing my generator since I already have a re-built one sitting in a box and then driving the car for about 45 minutes to see if this will fully charge the battery, then testing the charge capacity with a multimeter with the engine running.
Tony- 1953 sport coupe Sydney, Australia
to test the bsttery with a load you use a "battery load tester"...It has some coils that place a heavy draw on the battery and the voltage is tested with the draw and time is taken into consideration. If you have the required 100 AMP hour battery it will take 4 hours to charge it at a 25 amp charge. Its pretty difficult to get a 6 V battery fully charged in 45 minutes. The correct proceedure would be to fully charge the battery and then load test it. You are welcome to borrow my load tester :)Here in the US you can buy a 6 and 12 V tester for about $40.00.
Posts: 52 |
Thanks for this info on the battery load tester Gene. I installed my rebuilt generator last night. I noticed that the A and the F on the rebuilt unit were back to front. It had no tag on it so I don't know what serial number it was. The rebuilt unit did have the correct ID plate number for 53-54 as per the manual. When connecting I just made sure the connections corresponded to the regulator A & F. Also,looking at the end of the generator I pulled off, the brushes look a little worn but not too bad. I didn't pull it apart or anything. Anyway, I have the battery on high charge overnight to get it fully charged. Once it's done, I will connect the battery leads, polarise the generator, and drive about an hour. I think I'll wait to check out your load tester next time I visit the States:-) The problem I've found here is that there are not many people left that know how to test anything properly, the way things would have been done in the old days. I guess we have become a throw away society where people just replace, and it's sad that skills (particularly in auto repair) are slowly disappearing. That's what I've found here anyway.
Posts: 837 |
Being expected to perform certain time-honored rituals because this is the way you were always instructed to do it just isn’t enough for me. Since I’m the curious type I want to know the why behind my actions, you know, the principals. So, in answer to my question, “exactly what happens when you polarize the generator,” did some further research and found this article. Now you old timers probably won’t be interested in this or want to waste your time reading it, cuz ya all ready know all this, but there might just be a few of you that don’t know it all but would like understand this exercise in depth. http://web.utk.edu/~tprather/FoothillsTractorClub/TechTips/PolarizeGenerator.html Denny Graham Sandwich, IL
Posts: 11,162 |
I kinda figured it was something like dat! Wuzzn't real sure, jest knew it had to be done, because my Pappy told me to do it. Thanks!
Posts: 837 |
Same here Mack, pop was an old school mechanic trained in the 20's and he taught me young, all so worked auto parts in my teens and 20’s, but I'm now '66 pushing '67 and I been doing the same thing all my life and really never asked about the physics behind it. Apparently the pole pieces can retain some residual magnetism so ya just need to set it right for the polarity of your system. That's a surprise to me because I worked around electromagnets for almost 30 years at the USA's Jewel, Fermi National Particle Accelerator and that just didn't happen to the pole pieces in our magnets. In fact that was a characteristic that we tested the incoming pole piece material for. Denny Graham Sandwich, IL
Posts: 570 |
Here is a neat little something I learned today, Instead of going bonkers trying to isolate generator/regulator malfunctions for 4 months, look underneath your dash at the 2 wires going to the ammeter. Funny thing, if they arent tight... Gosh, I feel about as dumb as a mule with a spinning wheel.
The main wire come off the battery and attaches to the ammeter. all power then passes through the ammeter and goes on from there. The ammeter connections are very important. If the ammeter were to burn out the power would be cut-off at that point.
Posts: 570 |
It seems that since I corrected this. Everything else electrical rectified itself. In theory, poor connections create resistance, thus, not a proper flow of electrons giving the entire electrical system limit from full power. I thought it was wierd when I would go over a bump, or railroad tracks, the ammeter would jump to charge. But didn't last long. I figured it was making the regulator points bounce closed. Gene,in your years at the dealership have you ever encountered a poor, but not entirely cut off connection where it was functioning but not to full capacity? I can almost imagine all of the crazy things would have seen in the fix it yourself era full of farmers with a tin snip and a pliers.
Posts: 861 |
Years ago, about 40 of them to be honest, I had a 52 F*** flathead 8 that would run fine as long as it was on a halfway decent road. Hit a few bumps and it would start jerking like it was running out of gas. One dark night I lifted the hood and had some friends rock the front fenders. I could see sparks coming from one of the coil wires when they did that. Leave the car alone and it ran great. Replaced the wire and all was as good as it could be until I fully corrected the problem by getting another Chevy. :)
Bill
Posts: 52 |
Guys, Thanks for all this information. Just for the record I have checked all the connections and they are tight. There is however some original cracked wires under the dash mainly having to do with the turn signal connections into the original plastic connector, and some cracked wires where it joins onto the front terminal blocks. I have replaced the headlight wires and the connections to the coil, and generator to regulator. So I think I will replace the bad wires still remaining. A few days ago I took my battery to the battery shop and they put a battery load tester on it (as Gene suggested). He confirmed that although the battery had plenty of charge (about 6.3 Volts), it failed the load test. He said one or more of the cells in my 2 year & 2 month old battery has failed or sulphized ?, hence the reason it didn't hold its charge. It also made the indicators operate very slow or freeze, & gear shift indicator lamp did not come on when headlights were on and car was running. Bought a "deep cycle" 6 volt battery that fit the tray size. It is 550 CCA. The previous one was 650 CCA but that's all he had available. Haven't had one of these "deep cycle" batteries before but they apparently are more resilient to several discharge/recharge cycles as oposed to the standard auto battery, and have less current drain. Took the car out yesterday and it starts fine. At idle the amp gauge needle is slightly below centre but moves to the right at idle. I also opened the regulator lid and checked the points, nothing dirty, arced or stuck and my generator is now replaced with the rebuilt unit, and is charging fine. All lights appear to work as they should. Hopefully frustration solved.
Posts: 2,323 Likes: 6
Posts: 2,323 Likes: 6 |
I would be curious to know if anyone has adjusted one of the regulators that doesn't have the adjustment screws. I think they are just the worst thing to work on!
Just going from memory- On the later replacement regulators that did not have adjusting screws they bent the little tangs that the spinngs were hooked to.
Posts: 861 |
I'd forgotton about adjusting them. It was a VERY long time ago but yes, I did adjust them. I don't think I would try it today unless I had another regulator laying around so it would be safe for me to screw up.
Bill
Posts: 837 |
I've got a couple of them like that on the bench right now and a Delco with the screws. I know just what you mean, the adjustment needs to be very fine and bending the tabs on the after market regulators is next to impossible to get right. The Delco is very sensitive and much easier to resolve. As long as the contacts are clean and not burned and all the windings show continuity and aren't shorted the only thing left to getting them to operate reliably is the adjustment that must be done in fine increments. I would say that if your having problems with an after market regulator the best fix is to replace it. Denny Graham Sandwich, IL
Posts: 1,194 |
I was wandering the rows at a swap meet yesterday and was found a guy selling new replacement parts from an old inventory he purchased. He had multiple "rebuilt regulators". I'd never heard of a rebuilt regulator but had a number of them in the box. I don't remember the brand name. I was going to buy one just to check it out but figured different when the guy wouldn't take less than 50.00 for a GM 6 volt. On adjusting regulators, When I was working on my '50 this summer I had a couple regulators along with me at the starter shop. We had the generator all gone threw and working, then we wired up a delco regulator, no go. We check the points, all good. Then we adjusted it per the service manual and it started working but found that it was wanting to overcharge. It was also interesting that when we would stop spinning the generator sometimes the regulator would pick and and work and other times it wouldn't go. When it wouldn't go we would just touch the screwdriver to the cut-out relay and it would go. All the connections looked good. Then I had a aftermarket regulator that we hooked up. As Denny has said its tough at best to bend tabs for adjustments. We could get that regulator to kind of work. It always ended up that we felt it was acting almost like it was full fielding the regulator and I was nervous that it was going to overcharge my battery. I ended up getting a new regulator and once I got it adjusted the car charges perfect. I'm still hoping Denny can come up with a plan to repair these Delco regulators.
Thanks Don
Ya, rebuilt regulators were common years ago. Bought several over the years for my '51 Chevy. ![wink wink](/images/graemlins/default/wink.gif) :) :grin:
Posts: 837 |
The Echlin that ya sent me Don is one of those that needs the (bend a tab adjustment) I’ve messed with it for a while and just can’t get any consistency with it either. I have a late model Delco (probably made off shore) that is also adjusted by bending the tabs. The Delco that I am running on my ’50, 3600 is the old style and is fully adjustable with a screwdriver. I can hook the meter up to this one and make adjustments through out the range in .01v increments and it holds that setting. Not so with the other two. I suppose I should have mentioned a couple of other problems that you can encounter with a used regulator. Unless you have the resistance specs and a meter that will measure into fractions of and ohm it is difficult to diagnose a layer-to-layer short in the coils. The coil can be shorted internally and still check out ok. The regulator will appear to operate normally except it will stick once in awhile. Also the ground path is through the iron cores which double as rivets to mount the coils. Corrosion at this joint can ad resistance to the path, which upsets the adjustments in a regulator that has been in service for a while. There isn’t much you can do about either of these problems, it’s just not cost affective and you would have to manufacture new iron cores and wind new coils. Denny Graham Sandwich, IL
Posts: 1,866 |
Touch the field wire to ground and that will full field the generator. Increase engine speed and if there is no charge the generator is defective. If there is a charge then your regulator has a problem. ![wink wink](/images/graemlins/default/wink.gif) :) :grin: This is on my cub farmall with positive ground. I can't get my generator to charge after installing and sanding new brushes and cleaning armature. Took it to one place and he said it didn't charge. A friend hooked it up to a set of jumper cables and it turned like a motor. Took it to another and he said it charged the full amount. Reinstalled and nothing showed on the amp gauge. Touched the field wire to ground and it showed discharge full amount and the lights went dimmer. By the time I took the wire off ground the generator stared to smoke. Any ideas? Did I do something wrong being it's positive ground? If it turns with the jumper cables does that mean it's working? Will get the nieghbor tomorrow night to check it with his amperage gauge. I did polorize it "Bat" to "Gen" like the cub farmall book said. ![stressed stressed](/images/graemlins/default/stressed.gif)
If it turns with the jumper cables does that mean it's working? No. I have had generators that would motor fine but would not charge. ![beer2 beer2](/images/graemlins/default/beer03.gif)
Posts: 1,866 |
Thanks Dawg, being it showed discharging and lights got dim must mean it's not working. Will get it checked out again to see if it can be fixed. ![drink drink](/images/graemlins/default/drink.gif)
Posts: 1,866 |
OK. Just got back from a shop where I had my generator retested. It charges great when on a negative ground only. I have a positive ground on the cub farmall. Can this be reversed by polorizing or is it possible to change the wiring in the generator to switch it over to a positive ground? Couldn't find anything in our searches or on the internet. Thanks.
Posts: 11,162 |
Jerry, did your daddy never tell you about that special lever on a tractor? That one that he called "Lever B"? Well just lever B a positive ground Farmall Cub and the wheels won't get flopped over cross ways and run off into a frozen lake! BRRRRRR!
