#127071 09/13/08 12:35 AM
ChemEng Offline OP
I am currently using boat wheel bearing grease in my waterpump grease cup(1928 engine). I am concerned about grease entering into the cooling system and settling to the bottom of the radiator and eventually plugging the radiator. Is there a better grease to use, or can the waterpump be rebuilt to use a sealed bearing?
Thanks,
James.
You should be using regular water pump grease. You can purchase it here: http://www.lubriplate.com/
wink :) :grin:
The grease will settle as you say, slowly but inevitable. So you must keep an eye on this and clean the bottom tank to avoid plugging/boiling before it could damage the engine.
Use grease ment for the water pump.
:vcca:
Solan G, # 32797
ChemEng Offline OP
Thanks fot the waterpump grease info.
James,
VCCA member
The proper water pump grease that should be used,is a calcium based type.It's a very thick,tan brown colour,and is partially soluble in water.But as Solan mentioned,after a period of time,
it will buld up inside the water passages in the head,block & radiator core,and this type of grease can be easily flushed out.
chevy
CJP'S 29
ChemEng Offline OP
Thanks again CP'S29. I'll make sure to flush it right away!
James
