#12668 05/08/05 09:23 PM
dblclh Offline OP
hi ho, it is time for me to deal with my bent wheel. i need a 20" disc wheel for my 1930 coupe. ay suggestions. i've culled the net and was out bid on e-bay. what now? jim
jf lewis
#12669 05/08/05 11:58 PM
Your '30 Coupe should have '19" wheels. Only Chevrolet passenger to use 20" wheels was the '29 International models. Of course many years of trucks used 20" wheels and rims.
#12670 05/09/05 01:02 AM
Finding a 19 inch disc wheel in good condition is going to take a bit of looking too. :( :( :(
#12671 05/09/05 09:36 AM
I have some 19" and some 20" disc wheels, e-mail bwbugay@aol.com
#12672 08/09/05 10:01 PM
dblclh Offline OP
thanks all, don rossi in colorado sent me a 20" disc rim in nice condition and primed! $40 plus post. yes, this new kid (me) has learned the original issue for the '30 was 19" rims, somewhere along the way..... well, the 20s are mine and fine. thank you chevy b for the reply. as always, there is always something else. my most pressing need (god i hate the notion) now is the torque tube/rear end assembly, but not the mechanicals inside. my torque tube is bent and puts the drive shaft/ pinion coupling in an ugly bind. i have chewed through 4 ( yes, i swear) sleaves, splines etc. long story. last thing to replace. what think you all? dblclh
jf lewis
#12673 08/11/05 10:48 AM
If not too badly bent you can straighten. Put a straight edge on tube in 3 or 4 locations about equal distant apart. That will permit you to locate the bend or center of the bend. Mark it. Most bends I have found are just above the pinion connector and in line with the rear axle. If that is the case warm the tube at the bend (it can also be cold bent if you have heavy duty enough equipment) and pull or push carefully until it is a little past straight. Remove pressure and check again. If not in line with axle then it will be necessary to make a brace or use a strong beam to pull or push against. An auto body repair facility with frame straightening equipment should be able to do it too. That is if you can get them to do it.
#12674 08/11/05 09:50 PM
dblclh Offline OP
chipper, your suggestion sounds so plausable i think i'll give it a try. thanx for the reply.
the chevy six clatter
means nothing's the matter. jfl
jf lewis
#12675 08/11/05 10:54 PM
I've done it twice and it was not too tough. Used a comealong the first time which was a little tricky but a hydraulic body jack the second which was much easier.
#12676 08/13/05 01:59 AM
I have some 19 inch Disc wheels if you are interested drop me an E mail
Larry
#12677 08/15/05 11:13 PM
dblclh Offline OP
grinch, thanks for the offer but i am saddled with 5 pristeen tires and rims (20") and for now i must concentrate on more pressing items now that i have aquired a straight rim and painted it out to match the others. i mean, who will know but you folks? jim
jf lewis
#12678 10/10/05 01:07 PM
I just read this and I am now confused (as usual).
Does a 1929 Chevy Imperial Landau (IL) need 20" wheels (Is the IL an international model). Mine has 19" disks.
#12679 10/10/05 04:43 PM
20 inch wells are for 1929 and 19 inch wheels are for 1930 and 1931.
All 1929 models were of the International series.
laugh laugh laugh
#12680 10/10/05 07:51 PM
Well, another addition to the parts list. Any suggestion for a source?
#12681 10/11/05 07:54 AM
xxx Offline
Post an ad in the 'Parts wanted' catgory here on Chatter....might get lucky.
