#12651 05/01/05 01:01 AM
Is a 29 1/2 ton truck drive shaft longer than a 29 car or are they the same, what i need is a longer drive shaft to put in my 29 coupe, I have a 216 installed and i am coming up short the transmission and bell housing must not be the same size or length. What i need is about 2 1/2 inches. devil :o
#12652 05/01/05 10:05 AM
Both the torque tube housing and the driveshaft are the same for 1929 passenger car and 1/2 ton truck.
Why did you install a 216 engine? :confused: :confused: laugh laugh laugh
#12653 05/02/05 06:53 AM
Lou Offline
The 216 is about 2" shorter than the 194.
The 37 - 39 3-speed is 3" shorter than the '36 3-speed.
What parts are you using?
Look in the back of your parts book for Torque Tube lengths for different years.
#12654 05/05/05 09:10 PM
Thanks,Im using a 38 transmission I guess a 36 three speed would make up the difference with my 29 rear.Im going to Rinebeck N.Y. large swap meet first of the year.I am using the 216 beacuse i dont have the$$$ to re babbit the engine including the cam,I have saved everything so if I were to sell the car it would be complete. I drilled a total of four holes in the frame. I can live with that.
#12655 05/20/05 07:15 PM
the 28 torque tube and drive shaft is about 2" longer that the 29 and will fit in the only differance is the crownwheel Dia is slightly smaller about 1/8"
Jim
