Posts: 476 |
I'm dismantling the rear end from my 40 Chev 1/2 ton pickup for inspection. There was no gasket between the differential casting and the axle housing--it was sealed with blue silicone, so someone's been in there recently. The pinion engagement depth to the ring gear is controlled by shims placed in front of the front pinion bearing on the bearing seat in the housing. The shop manual indicates that the normal setup is two shims--a .015" and a .018" for a total of .033". The parts catalog calls for a gasket between the differential casting face and the axle housing. The thickness of this gasket will have a direct impact on the pinion depth. Can anyone tell me the correct thickness of the gasket. Thanks,
Mark Yeamans VCCA #35724
The thickness of the gasket mentioned, will not have any affect on the ring and pinion setting. There should be a very thin gasket in front and for the back cover.
The gasket used between the differential carrier and the axle housing is paper. The rear axle housing cover uses a cork gasket.  :) :grin:
Posts: 51 |
I agree with AntiqueMechanic's response. When I took mine off a month ago, the gasket had compressed to something less than 1 mil - less than a sheet of paper, but thicker than tissue paper.
Lyn Gomes 1955 Chevy 1st series truck
The thickness of the gasket will not change the ring gear to pinion settings as they are both supported and mounted in the differential housing. Infact if the shop manual method of setting the clearence is followd the adjustement is made with the housing out of the banjo housing.
Posts: 476 |
Thanks for all the responses. On looking at the unit more closely, it's obvious that the differential housing to axle housing gasket does not affect the pinion depth adjustment, as the ring and pinion are a complete sub-assembly indepenent of the axle housing. Also, on cleaning up my unit, I discovered that there was, in fact, a paper gasket stuck to the axle housing. It measured .010" thick. A seller on Ebay has a NOS GM gasket for sale, and I asked him to measure the thickness. He replied that it measures .010".
Mark
Posts: 837 |
JYD, you mentioned a cork gasket behind the cover. I've just disassembled my original 1950, 3604 Eaton HO52 to replace the 4.57 with it nice 4.10. I was surprised to find a cork gasket behind the cover. I bought a haf dozen gaskets from AutoZone, and they are all the thin paper Felpro gaskets which are fine for the carrier side. But is anyone making the cork gaskets for the rear covers??? Denny Graham Sandwich, IL
Purchase a roll of cork gasket material and cut your own gasket.
But is anyone making the cork gaskets for the rear covers??? Same answer as always......the Filling Station. Check out their catalog. By the way, here is a rule of thumb to go by: Between two machined surfaces a paper gasket will be used. Between a machined surface and a stamped steel surface a cork gasket will be used.  :) :grin:
Posts: 1,441 |
I used a paper gasket for the cover side on my 37 with no problems. Jeff
VCCA #45194
Posts: 837 |
Well I would buy into that with sheet metal as on the engine, and since the rear cover is basically a sheet metal cover, I would go along with your theory and I can understand why they used the cork. But the rear axle housing is a purty heavy forging. Unlike the later housing that were two stamped half’s welded together, the HO52 housing actually appears to be a forging. It is a full 9/16”+ thick at it’s flange and is a precision machined item. I have been in contact with the people that maintained the vehicle for the village that bought it new. I got it right from them when they decided to auction it off. There is no record of any work ever being done on the differential. So I'm 99.9% sure that I'm the first one into this axle since it came from the factory and between the carrier and the housing is a thin paper gasket (.006”). A thick gasket in this location can push the axles shafts forward and load the side gears and outer wheel bearings. Also you would not want a thick gasket in the area because of the torque that occurs between the carrier and housing. And I just checked with Scott at ”˜The Filling Station’ and the #G12087E differential gasket is paper, not cork as were the Fel-Pro ones that I got from AutoZone. I suppose I can cut a cork gasket from the 1/16" material that I have here for the rear. The only cork material that I can get is only 12" wide so it will be about an eighth shy on both sides, the cover is 12 1/4". When I was a kid, working in the auto parts store we had 3ft rolls of all types of gasket material on a rack that we could cut any size gasket from. Sure wish you could find that today instead of these prepackaged 12” rolls! And I will again use the thin paper one for the front like the original one was. Hey, JYD, thanks for stirring the pot, it made me dig a little deeper into it all. Denny Graham Sandwich, IL
