#12375 04/04/05 04:12 PM
Hi
I have now a problem witch the starter....
Model Delco Remy 714-L
the starter have new bearings bushings i was buy a new battery the wire are okalso the conect to the starter switch.
The problem now is if the engine is cold the starter turns well...but wen the engine is hot the starter hafe not to mutch power to turn the engine well (more compresion) i clean the micra copper with a hacksaw blade the are now clean
but it is the same proplem.....i think the copper commutator diameter is to small...
I cal vintage auto parts also fillingstation but the dont have a new commutator:-(
baby somone knows for a rebuilt starter with a new commutator
sorry for my bad english:-)
thanks
Switzerland
#12376 04/04/05 05:09 PM
Has your engine been rebuilt (new pistons) recently? If the starter works when cold, then it probably is not the starter. Do you retard the spark when starting the engine hot?
Agrin
#12377 04/04/05 05:38 PM
The problem is most likely the ground circuit. As temperature rises so can the resistance in a corroded or dirty connection. Clean the connections. If that does not improve the hot starting then connect a good ground from the starter direct to the battery. That should solve the problem if the connection or current path is the problem.
#12378 04/04/05 05:47 PM
Hi Ray
I was buy the car 10 years ago in canada and now after 10 years restauration i drive with the car
the dealer was told me the engine was rebuild...
i was put the timing from 12 to 18 degrees (18 degrees at 750 R.P.M so wen i start the engine the timing is at 12 degrees wen i drive the car now at 18 degrees the cars runs very well...maby i have to put the ignition back to 5 degrees to start???but there is plate at the distributor wen i turn the ignition back from 18 degrees back to 12 degrees that is the maximum....maby i have to make a bigger hole in that plate the i can make a biger turn from 5 degrees to 18 degrees...
Switzerland
#12379 04/04/05 05:56 PM
Hi Cipper
Ok i wanna tray to make a second groud cable direct from the battery ground to the starter
greetings
from Switzerland
#12380 04/04/05 06:07 PM
If the car starts without problem while cold and you have retarded the spark, then don't change anything else about the timing.
Am I to understand the car has not been driven very much since the engine was rebuilt several years ago? If so, then it needs to be operated.
With some more operating time on the engine it will begin to start easier.
Agrin
#12381 04/04/05 06:20 PM
how mutch degrees do you have wen you start your engine????
#12382 04/04/05 09:51 PM
My car is a 1933 so it is completely different.
Agrin
#12383 04/05/05 02:24 PM
now i change the timing from 18 until 12 degrees now i start the enging with 5 degrees but it is not mutch better....:-(((
think that i have to cange the armautre assembly...but it is hart to find....
#12384 04/06/05 02:42 PM
Switzerland,
I have a remanufactored statrer armature for that 1931 Chevy. E-mail me.
