#123632 07/16/08 04:01 PM
6wheel Offline OP
re: my 31 coupe's floor - the rubber floor mat will cover the area in front of the seat. Is there supposed to be any covering beside the seat or behind the seat? Was there any padding under the floor mat?
I know that an ID plate is to be tacked to the floor on the passenger side. Can someone advise as to its proper location in that area? My sills are new, and I don't have the old ones for reference.
From a previous post I learned that originally there was no covering of the trunk floor. Was there an accessory rubber mat sold for that area?
Thanks.
Your serial number question can be answered at this link http://1931chevrolet.com/
There's a picture at spec P6
Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
There were small rubber mats on the floor and each side of the front seat.
The floor mat used a jute backing.
No accessory trunk mat was available from Chevrolet for that year.
wink :) :grin:
This is interesting..... Should my '29 and '30 cars have jute backing under the front floor mats? I have the rubber mats with the bowties, but no backing. I thought they just rested right on the floor boards.
All the Best, Chip
"It's wise to choose a SIX"
Chip #123675 07/17/08 09:59 AM
Yep, the mats had a jute backing.
wink :) :grin:
Does the jute stop a couple of inches from the edge all the way around or does it exactly match the mat?
Is it glued to the underside of the rubber mat or loose laid?
How thick?
THANKS!
Chip
Chip #123686 07/17/08 07:41 PM
The jute backing stopped a couple of inches from the edge of the mat. The jute backing was glued to the underside of the mat.
wink :) :grin:
6wheel Offline OP
Thanks Dog and Jiaccino. Dog, you wrote, "There were small rubber mats on the floor and each side of the front seat."
Where these small mats plain rubber, or did they have little bow ties, or? On the sides of the seat, did they cover the entire visible area? Were they glued down?
Re: the serial number plate - the 31 chevy website says, "Located a few inches forward of the front seat under the floor mat." Can anyone add a little more info to that like how many inches? I'm try to be as accurate as possible with my restoration.
Thanks.
The serial number plate on the '31 Roadster and Phaeton was nailed to the front seat riser on the passenger side. The Fisher bodied cars had the serial number plate on the main sill.
On my 30 coupe they are plain rubber cut to cover all the visible area from about the front mat (1-1/2 inch from the front edge of the seat)to the back corner trim board. And extend from the raised ridge on the sill of the rocker molding to the metal seat well. Mine are not glued down. Mine are also as hard and brittle as a potato chip and may have shrunk a slight bit. :)
Those who would give up essential liberty to purchase a little temporary safety deserve neither liberty nor safety. B.F.
The side mats were plain rubber and they covered the entire visible area. The side mats were not glued down.
wink :) :grin:
6wheel Offline OP
Thanks Dog, Chipper and Speedy. I appreciate the help. I'll start my search for some plain rubber. Was jute backing under the side mats as well?
No backing under the side mats.
wink :) :grin:
How thick is the jute padding under the mat?
woody
woody #123719 07/18/08 11:11 AM
Not very thick.
wink :) :grin:
Thanks for the info, Dawg. I'll order some "not very thick" jute matting as soon as I find that size in my catalog!!!
devil devil wazzup :vcca:
Chip #123743 07/18/08 06:50 PM
You only have two choices on the jute backing.....thick and not very thick. I suggest that you go with the "not very thick"!
wink :) :grin:
I feel thick about this whole discussion.......
But thanks for the info. As always, you're the guy with
the answers.
All the Best,
Chip.
Chip #123774 07/19/08 11:19 AM
I need to get some of that "not very thick" jute backing as well. Where is the best place to order it?
The Filling Station in Lebanon, Oregon.
wink :) :grin:
This is thickening!
Chat Group Chapter Member
Current rides;
1968 Camaro rs/SS 350 4spd
2000 Blazer LT
2005 Malibu Maxx
2007 Acura TDX
Last total restoration;
1932 Sport Coupe
