Posts: 10 |
I have a 1950 Chevy 3100 1/2 tone truck, with a 216 c.i. in-line 6 and a 6 volt electrical system. Externally mounted on the outside of the coil is what looks like a condensor/resistor. I managed to break the wire and am looking to replace it. From what I could find on the Internet, it appears to be a discharge resistor. On the end of the resistor it has a "D-R", a number "1910147" and the marking "3mf". I found some other Internet info that refers to it (or something else?) as a ballast resistor. My understanding is that it supports the coil at start-up and low rpm's. Anyway.... wonder where I can get one?
Hi DWinn, As a first time poster, a great big welcome to our site. Hope you find us helpful and neighborly. The item you are looking at is the condenser. The 6-volt system does not use a resistor. Go to your nearest parts house and order a condenser for a 1954 car. That will solve your problem. Any more questions, come on back.
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
DWinn With the marking "3mf" indicates it is a condensor (capacitor in electronic terminology) not a resistor. As Ray suggested most part stores should be able to supply. Tony
Posts: 11,162 |
This 3mf condensor on the outside of the distributor on a 49 probably is to reduce static noise in the AM radio. I think those ignition condensers are usually rated at 2mf.
Posts: 1,213 Likes: 1
Posts: 1,213 Likes: 1 |
From my 1941 edition DELCO-REMY Catalog A-101,condensers (rated in microfarads),have certain applications,relative to the speed range of the engine they will be used on. High speed range engines(please note,the book gives no actual rev range),require a low condenser value of aproximately 0.2uF capacity. Medium speed range engines require a medium value condenser of approximately 0.3uF capacity. Low speed engines(stationary engines,tractors etc.)require a high value condenser of approximately 0.4uF. Hope this helps out.
CJP'S 29
Posts: 11,162 |
That is good to know. so instead of 2 or 3mF it should have been 0.2uF or 0.3 uF. I also suppose that an eight cylinder distributor would require a different uF condenser than a four cylinder engine, at the same RPM, that seems logical to me.
Posts: 10 |
CJP's 29:
As stated by others above, it the condensor just for static, or does the condensor have something to do with coil sccording to your book. Thanks!
The condenser is critical to the operation of the ignition system. The condenser can be installed on the coil (as this one apparently is) or on the distributor. As a final check, remove the distributor cap and see if there is an internal condenser mounted by the points. If so, then the condenser in question is a radio item. It will be connected to the 6-volt + line to the coil.
