#122529 06/23/08 08:05 AM
Tony53 Offline OP
Hi there,
I have a frustrating query relating to my 53 hardtop.
The right door latch has never worked properly since installing the door handles after the bodywork. The left works fine.
To open a locked door from outside you need to put the key in, turn to release the lock mechanism /raise inside knob, and depress button all at the same time to open the door. You then need to unrelease it from the inside as the outside button stays in a locked position (that is it won't depress). I figure something is missing or broken in the latch. I originally thought the rod connecting the button to the latch was slightly short, or not in the latch hole properly after installing handle shields but I checked and it seems fine & no prob with other side
Anyone have any suggestions or should I look for another latch ?
Also is a front door latch from a 4 door car the same as a hardtop or 2 door car ?
Thanks Tony
Tony- 1953 sport coupe
Sydney, Australia
latch mechanisms are inter changeable on all the cars. The outside door handles are not due to contour of door skin on the Hard top.
Walt D
1934 Mstr 4 dr/sidemnts
1937 1/2 ton P/U
1953 Bel Air HT
1946 Aeronca 7-AC Champ
Tony53 Offline OP
Thanks Walt.
I had a look through some of Chevrolet Service News for 1953 and found one with information of the latch mechanism adjustments. I'll also have a read through the manual. It may be an adjustment or something simple. If that fails I have another latch mechanism, so I'll install that one and see if it works properly. Thanks Tony
Sydney, Australia
