#12251 03/29/05 07:49 AM
Hello
how mutch is the max. speed form the car? my 1930 runs in the moment 44 miles
so i take care for the engine the was not running the 10 !!
I was change the sparks the ingnition cabels ...and a lot more....also a new rebuilding kit for the carb also i adjust the vales the engine runs very vell and soft and is easy to start but i think wen i drive in the max speed is the power is low....
if i have the time i want measure the compression or maby i play with the carb idle adjustment
Switzerland
#12252 03/29/05 10:24 AM
With the stock factory ring and pinion, and with your engine up to snuff, your car should be able to go at least 55 miles per hour. A lot of guys run their cars around 45 to 55 miles per hour. If you have the 3.50 ring and pinion in your car from Larry Jackson, then 60 to 65 miles per hour would be normal.
Check your timing. If your engine is running retarded power and maximum speed will be diminished laugh laugh laugh
#12253 03/29/05 11:01 AM
I had now 10 years work on the car.....now i can drive it
i was make last week the registration in switzerland...it was alot of work to get the registration....the control the car like a new car!!!!!!
What kind of oil do you use for the engine?
the timing of the engine is now 12 degrees ist that ok?
Switzerland
#12254 03/29/05 11:18 AM
12 degrees is the factory setting. However, if you want to improve performance and power, install AC-C87 spark plugs and gap them at .040". Bump your timing to 18 degrees (that's when the 12 degree timing mark is just about ready to disappear out of the top of the timing hole (advanced side), and you will notice a big difference in the way the car performs. laugh laugh laugh
#12255 03/29/05 12:51 PM
Here is a link that will provide you some information also. It has a lot of good and interesting information with it. It is all about 1931 but some info can relate to the 1930. chevy http://1931chevrolet.com/troubleshooting.htm#why
Seeing the USA in a (1930) Chevrolet
#12256 03/31/05 02:32 AM
Great:-)
The car runs now well
Switzerland
#12257 03/31/05 10:32 AM
Cool! laugh laugh laugh wink
#12258 03/31/05 01:25 PM
can I increase the gap to .040" and advance six more degrees using c-86 plugs?..
ok epi
#12259 03/31/05 05:47 PM
Yep! We talked about this many times in the past on Chevy Chatter regarding the AC-C86 plugs, which are now discontinued. Also, the information on Billy Boy's 1931 web site covers the AC C-86 plugs and the increased timing as well. laugh laugh laugh
#12260 03/31/05 06:03 PM
thanks...
ok epi
#12261 03/31/05 06:10 PM
You bet! laugh laugh laugh
