pwj Offline OP
Hi guys
Can any one help me. I am having my crank shaft ground. On the clutch end there is a pointed peg which is in line with the centre of the shaft. Does any one know to what purpose this serves. This will have to be cut off to be ground.
pwj (clayhead)
Is it a pilot for the transmission main shaft??
pwj Offline OP
Link to image
Does this help to identify what i was talking about?
As i am abit of a novice at all of this
Paul
pwj (clayhead)
Hi Paul
My best guess is that it improves the lubrication of the roller bearing (cup and cone) for the Clutch spring tension rod. I guess your truck has a cone clutch? If not, I have no idea. But I'm only a novice too.
Per-Åke Larsson
