Posts: 408 |
I recently dismantled my tie rod ends.I had noticed a bit of wear on the shaft openings and found that "everything" is somewhat worn. This does not come as a surprise as I have used the car regularly for the past sixteen years without lubricating them and imagine that it has not been done for years,if ever.They have no grease fittings. I have a spare "38" front end and notice that it appears similar though it does have grease nipples. QUESTION!!!! "Can I use tie rod ends, balls, cups etc from a later model on a "28"? Terry
I would do a experimental assembly to check sizes and fit. If it fits, do the job for keeps.
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
Terry.
The Filling Station sells replacement balls,you will have to measurethe length and diameter to get a match, they are piened over to hold them into the steering arm arent they? same as on 31-32.
You could also tap and thread the back of your 28 fittings to allow pressure greasing fittings to be fitted Regards jack
JACK
