#122236 06/15/08 04:01 PM
jon-l Offline OP
looking for information on how to restore a speedometer/odometer for 48 chev. car. Or anyone who does that type of thing that charges a resonable fee.Called some of the guys in hemmings but they are in the $200- $400 range
Not sure just what you mean my restored. I had a speedometer cleaned, lubricated and recalibrated by a local speedometer shop for around $50.00
jon-l Offline OP
the instrument works fine but needs to have the dial, needle and odometer drums restored
If you only need to resurface it, Jim Carter makes decals for the face and odometer drum that will make it look like new. You will want to lubricate it when you have it apart.
Richard
I think that "jon-l" has a 1948 passenger car and Jim Carter's catalog indicates that he has the new gauge faces for trucks only. The Filling Station has the speedometer and gauges decal set for a 1948 passenger car.
wink :) :grin:
JYD- You are quite correct. I didn't even notice that we were discussing a car. I must have trucks on the brain.
Richard
OK.... Why do I get the horse icon when I type JYD? I have never had that happen????
Richard
That's the way Billy Boy Barker has it set up. The icon has been appearing for several years. I think it's cool. Anyway, if you type "Junkyard Dog" it won't appear. The icon only shows up when you type "J Y D".
bigl wink :grin:
Former ChatMaster
ChatMaster - 5,000
Former ChatMaster
ChatMaster - 5,000
yep.. and there's a couple of other ones that work that way too....
Try "t f s" -- without the spaces.
Or "bb 31" -- without spaces
Or "chev 40" -- also without spaces.
newangel Too much time on my hands.... devil
Bill Barker
(VCCA Member: 9802)
jon-l Offline OP
thanks for the info; I ordered a set of decals from chevs of the 40s and will attempt to do the job. any secrets regards getting the odometer drums out to put the decals on?
When you look at the odometer from the rear you will see a brass V shaped clip on one end. Remove the clip (from solid end) with a needle nose and the odometer will slide over to one side and then can be removed.
tfs
bb31
chev40
Had to try them out. To much time on my hands.
devil croc yay
jon-l Offline OP
chevgene, thanks for the tip. any tips on removing the needle?[gosh, what a good place to get good info, thanks]
The needle can be pulled off. Some times they come off easy and some times hard.
jon-l Offline OP
got my decals from chevs/40s and it went very well. got the speedometer,gas,amp and oil pressure done in less than 1 hour and they look SUPER. thanks for all the info.anyone thinking of doing this job should not be afraid to give it a go.
